Linux SDK w/ startup kit
Online Technical Assistance for DI-148U, DI-158U/UP, DI-194RS, DI-154RS, and DI-195B Starter Kits.
Moderator: smacdonald
Postby sean.matthews » Thu Sep 17, 2009 2:10 pm
When using the Linux SDK with the starter kit, what features are NOT available? Can I set the voltage limits (+/- 10V, 0-10V, etc.)?
Thanks,
Sean
sean.matthews
Re: Linux SDK w/ startup kit
Postby sean.matthews » Thu Sep 17, 2009 3:49 pm
Also, can the Linux SDK use more than one analog input channel at a time?
sean.matthews
Postby DaqGuy » Thu Sep 17, 2009 4:29 pm
What specific starter kit model do you have?
DaqGuy
Postby frmsup » Fri Sep 18, 2009 7:45 am
The SDK only supports the 154/194 starter kits. It supports acquiring from all analog and/or digital inputs. It doesn't have special support for the square wave generator; outputs the wave if digital channels aren't being acquired, disables it otherwise. The rest is mostly a limit of the starter kit devices themselves. Also, the SDK doesn't support any of the advanced features available in WinDaq, as WinDaq provides them, not the hardware.
frmsup
Site Admin
Postby sean.matthews » Fri Sep 18, 2009 8:55 am
Thanks for your replies.
I have the DI-194RS. Does the SDK support changing the voltage limits on each channel? Or, is this a WinDaq addition?
-Sean
sean.matthews
Postby frmsup » Fri Sep 18, 2009 9:02 am
The DI-194RS has a hardware range of +-10V, no gain settings, so it's always +-10V. If you are referring to the scaling or conversion to engineering units, yes, that's a WinDaq thing. The SDK simply provides you a way to configure the hardware device and read the resulting data.
frmsup
Site Admin
Postby Ido » Wed Aug 18, 2010 11:41 am
Hi everyone
Thank you for Having developped a SDK for Linuxian.
Hi plan seriously to order a DI-148 or a DI-158.
Howver a need to know if the sDK support higher sampling rate than 240hz .
That is to say can we sample at 14.4khz ???
Otherwise is the design of the sdk allow to go through the 240hz limit ?
Thank you
Ido
Postby DaqGuy » Wed Aug 18, 2010 11:45 am
Maximum sample rate is limted only to the efficiency of your program and the speed of your PC or 14.4 KHz, whichever is smaller, if you use the SDK.
DaqGuy
Postby Ido » Wed Aug 18, 2010 12:08 pm
Hi Thank You for your answers.
Do you mean that the program have to loop for queries on the device.
Ido
Postby Ido » Wed Aug 18, 2010 12:13 pm
I don't know how to edit post.
Actually i was thinking of setting a rate to the hardware then reading a internal buffer.
Maybe thi architecture is for hiher price device...
Ido
Postby Ido » Wed Aug 18, 2010 12:34 pm
It seems that the D148 have a 2kb buffer and have a scnning mode.
Is this mode , provided in WinDaq® High Speed Data Acquisition is available in the linux SDK.
Otherwise is dataq plan to document this part.
Thank You
Ido
Postby DaqGuy » Wed Aug 18, 2010 12:49 pm
The Linux SDK does not support the DI-148 or the -158, and there are no plans to provide one for that OS.
DaqGuy
Return to DATAQ Start Kit Support
Who is online
Users browsing this forum: No registered users and 1 guest
